Results 1 to 10 of 13
Thread: Socket wrench for toilet oval water shutoff valve
    May 2016
    Don42's Tools
    The fill valve on my toilet has a slow leak. That’s the one that a float is supposed to shut off when the tank refills. Mine doesn’t quite shut off. It dribbles a little.
    In order to replace it, I need to shut off the water feed to the toilet. That’s one of those little valves with the oval handles.
    Like most plumbing opportunities, It’s in a place that’s awkward to get at – and like most older things (including me) it is very stiff. I can’t turn it with my bare hand and I can’t quite get a pliers or wrench on it. So today, rather than fixing the toilet as was my plan for today, I made a tool. It’s an oval socket wrench to fit the handle of an oval-handled toilet valve.
    Socket wrench for toilet oval water shutoff valve-toilet_valve_wrench_1.jpg Socket wrench for toilet oval water shutoff valve-toilet_valve_wrench_2.jpg
    I cut a slightly oversized oval out of 1/8” steel and shaped it with the belt sander. Then I cut a 6” piece of 1/8 x 3/4 steel, welded one corner of it to the side of the steel ellipse. Then, while heating it to orange heat with an oxy-acetylene torch I bent it around the oval until it enclosed the oval. Then I welded it all round to the ellipse and welded the ends together. Then I cut off a piece of ¾” hex stock and welded that to the ellipse from the inside. I'd turned a 1/2" boss on it that goes thru a 1/2" hole in the oval. The hex will fit a 3/4" socket on the end of a long extension and driven by a 1/2" ratchet wrench.
  2. The Following 12 Users Say Thank You to Don42 For This Useful Post:
    baja (May 6, 2020), benkeller3 (May 11, 2020), blkadder (Feb 19, 2023), Carnel (May 6, 2020), Jon (May 5, 2020), llh49 (May 6, 2020), olderdan (May 5, 2020), Paul Jones (May 10, 2020), rlm98253 (May 9, 2020), Sleykin (May 12, 2020), thevillageinn (May 5, 2020), Toolmaker51 (May 6, 2020)
    Thanks Don42! We've added your Toilet Valve Socket to our Miscellaneous category,
    as well as to your builder page: Don42's Homemade Tools. Your receipt:
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    Nice solution to your problem. I hope it does the trick!
    As a maintenance guy in an apartment community I’ve been on the wrong side of those valves plenty of times - things like bad washers and seats or the handle snapping off in my hand. I always take replacements with me when I go to work on an old faucet or toilet. The quickest adjustment can turn into a major project in the blink of an eye.
  5. The Following 2 Users Say Thank You to thevillageinn For This Useful Post:
    Paul Jones (May 10, 2020), Tuomas (May 6, 2020)
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    Did you try loosening off the packing nut when trying to turn the handle? That usually loosens them up.
    I hate those handles!
    While musing on alternate designs for such a tool, it occurred to me that a beefier variant of this style of gripper...
    https://www.amazon.com/Squadron-Prod...784647&sr=8-14
    would accommodate many odd-shaped handle (OSH) designs.
    Imagine a 1/8" steel plate with an array of holes drilled through it. The back side of this plate has a chunk of 3/8" hex steel welded in the middle.
    In use bolts would be passed through the holes in a pattern that trapped the OSH. The bolts would be secured in place with nuts. Then a socket wrench would be used on the 3/8" hex steel to torque the OSH.
    Home Shop Freeware
  8. The Following User Says Thank You to mklotz For This Useful Post:
    olderdan's Tools
    I also detest those handles, designed by someone who never had to use one in the field like so many things these days. I once installed a shower enclosure for a customer which leaked in use, after several attempts to fix it I gave up and called the suppliers service engineer who on arrival said I told them they would have trouble marketing this but they would not listen to me saying it works fine in computer design
    I have only encountered the plastic bodied variety but has the same handle, I would remove the central screw and handle and use an extended radiator key to work on the exposed square shaft. We all find our own ways to get through the days problems.
  10. The Following User Says Thank You to olderdan For This Useful Post:
    mwmkravchenko (May 11, 2020)
  11. #7
    jdurand's Tools
    One of the things we do is design PC boards. Some of the very dense parts can be close to impossible to connect to. I wound up being a speaker at an electronics trade show regarding how the part designers never actually had to USE their parts.
    A processor in a ball grid array specified a certain number and sizes of capacitors to be placed on the back of the PC board directly beneath the power pins. We couldn't get them to fit so I contacted the engineers there (I used to have a direct line to them as an expert user). They said on their test boards they only used half the capacitors...because they couldn't get them to fit. But they didn't change the specification before publishing it.
    A ball grid array with rows and rows of pins would require many may layers of PC board to connect. The engineers said there was no need for all those layers. This escalated until we got them to send an engineer to our office. We sat him in front of the CAD system and said SHOW US. He couldn't do it without adding MORE layers than we had proposed. The board wound up being 14 layers.
    A high speed chip specified all the fast lines had to be 0.025" wide and on the same side of the board, but the pins they came off of were on 0.015" centers. I need a space squeezer to make that work!
  12. The Following User Says Thank You to jdurand For This Useful Post:
  13. #8
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    If'n one used 3/16" or 1/4" plate and threaded the holes, nuts wouldn't be needed.
  14. #9
    Jul 2019
    Ohio, USA
    A high speed chip specified all the fast lines had to be 0.025" wide and on the same side of the board, but the https://www.homemadetools.net/forum/...lleyes.pngpins they came off of were on 0.015" centers. I need a space squeezer to make that work!
    Did your autorouter jump out of the computer and roll on the floor laughing?
  15. The Following User Says Thank You to FEM2008 For This Useful Post:
  16. #10
    jdurand's Tools
    She did have some unkind comments about whoever wrote that spec.
    I happen to be married to my autorouter, "Sharon, here's a board to do" and presto, a beautiful PC board appears in the CAD system. She also cooks for me (except when I do some of the cooking).
  17. The Following 2 Users Say Thank You to jdurand For This Useful Post:
    mwmkravchenko (May 11, 2020), Sleykin (May 12, 2020)
