Results 1 to 10 of 12
Thread: Some garage made art projects/gifts
  1. #9
    Supporting Member Workshopshed's Avatar
    Mar 2013
    Suffolk, UK
    Workshopshed's Tools
    The wheels on the flea chariot are 5mm, the hubs just 2mm. I silver soldered the axle to the carriage with a small torch then used soft solder and carefully applied flux to attach those so that the wheels still turn.
    I had the flea shipped in from the USA, the wire was a bit tricky as it snapped easily when making the tight turns. I probably should have annealed it but as the other end was already attached to the flea it was not easy. The coin is about the size of a 2p or US Quarter.
    Andy from Workshopshed
    "Making and repairing things in a shed at the bottom of the garden"
    workshopshed.com
  2. The Following User Says Thank You to Workshopshed For This Useful Post:
    jere (Apr 30, 2015)
