Thread: Square drive coupling and key for taper lock pulley
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    After broaching the square in the adaptor to drive my slip rolls via the industrial clutched sewing machine motor setup. The keyway and key needed to be cut and made. Link to motor set up: Powering homemade sheet metal tooling (Table and motor arrangement)
    Broaching link: Broach square holes with D-bit
    Homemade slip rollers link: http://homemadetools.net/forum/sheet...553#post143087
    This post covers the adaptor bush completion and the making of the key.
    The taper lock pulley and bushed arrived so the first process was to cut the keyway. The adaptor bush was set up in the mill vice and to ensure the orientation of square to keyway position a parallel was used to align.
    Square drive coupling and key for taper lock pulley-set-up-mill.jpg Parallel used across vice jaws
    Square drive coupling and key for taper lock pulley-roughing-out.jpg Roughing out keyway
    Square drive coupling and key for taper lock pulley-milling-keyway.jpg Square drive coupling and key for taper lock pulley-finished-keyway.jpg Finished keyway
    After milling the keyway this was then used as a gauge to make the key.
    The key was made from a piece of 3/8" square steel cut just over length and ends filed to full radius.
    One end filed.
    The machined keyway used as a gauge to check fit.
    I machine a screw in the middle of the key to aid removal.
    The key is pushed into the keyway and this highlights the tight spots once removed.
    Witness spots identifying high spots on key.
    The high spots are removed on the homemade lapping plate.Link to lapping plate: Recycled steel if you can find any.
    Square drive coupling and key for taper lock pulley-taper-lock.jpg Square drive coupling and key for taper lock pulley-fitted.jpg
    Taper bush and adapter
    Completed assembly ready to fit to slip rollers.
    Square drive coupling and key for taper lock pulley-front.jpg Square drive coupling and key for taper lock pulley-back.jpg
    Pulley pushed on slip rolls waiting to be positioned correctly and bolted to table top via M8 prong tee nuts.
    Thank you for viewing
    The Home Engineer
  2. The Following 10 Users Say Thank You to thehomeengineer For This Useful Post:
    baja (Jan 21, 2020), emu roo (Nov 25, 2025), freddo4 (Jun 1, 2022), jim paine (Jan 20, 2020), Jon (Jan 23, 2020), Karl_H (Jan 20, 2020), Okapi (Jan 21, 2020), Scotsman Hosie (Jan 26, 2020), Scotty12 (Jan 20, 2020), Toolmaker51 (Jun 1, 2022)
    Thanks thehomeengineer! We've added your Pulley Key Remover to our Miscellaneous category,
    Mar 2013
    Switzerland
    Okapi's Tools
    A good refreshment for new workers, especially for the screw in the key which was always made when I make my apprenticeship and neglected since a long time resulting in keys with dents made with about everything…
  6. The Following User Says Thank You to Okapi For This Useful Post:
