Yep. That's a great helmet. Only minus on it, is that you "can't" tilt your head sideways. That's required sometimes, to see tight spots.
In that case you need to support it with your shoulder or hand, otherwise it spins in your head.
Here using air supplied helmets with particle filter are required in "continous welding job ". That's one that employer has to offer.
Welding causes Copd, mostly reason is ozone, but also fine dust.
That's why tig welders should use respirators too, even that there is no visual "smoke".
For heavy grinding i have another mask with actual helmet that really protects if grinding wheel "explodes".
When i started in my workplace, 21 years ago. I replaced a worker who died when grinding wheel "explodes".
He was using 6000rpm wheel in 12000rpm grinder in full speed. Reason to this was, that he wanted to get job done before the shift ends.
Choosed to take a short cut. That shouldn't happen.
"The prevalence of COPD was significantly higher in welders than in office workers (15.2% vs. 4.3%, P = 0,029). COPD in both examined groups was close related to age over 45 years, while in welders significant association was registered for duration of workplace exposure longer than 20 years..."
short cuts are out but yet I see some repeatedly do it. A friend simply closes his eyes for short/ spot type welds and grinding. eye lids did not protect him when a cutting disc exploded probably, i think, from moisture from his tool box storage. I've had a couple of the 1mm ones fly apart.
