Results 1 to 10 of 11
Thread: Stretch that drill bit
    Sometimes I need a longer brill bit
    Today was one of those times. I needed to frill through a 2x4 laminated table plus 2 6x6 s and 1/8" steel to mount the table in my machine shop van
    I torch welded a 36" piece of 3/8" 1018 round rod to a 13/32" bit
    I only needed a bit about 18" long but if anything is worth doing it is worth over doing, besides I can always cut it off later.
    After grinding both pieces to a point
    I welded them together with a torch with a slightly carbonizing flame IE a long center feather instead of a shorter oxidizing flame
    the filler was a 1/8" 7018 rod with the flux removed
    I kept the torch on the weld area slowly allowing the weld to cool as I moved the torch farther away
    As you can see the bit is plenty long
  2. The Following 10 Users Say Thank You to Frank S For This Useful Post:
    Andyt (Aug 16, 2019), baja (Aug 16, 2019), blkadder (Mar 26, 2016), C-Bag (Apr 5, 2016), Christophe Mineau (Apr 8, 2016), emu roo (Mar 17, 2025), Jon (Mar 3, 2016), kbalch (Mar 5, 2016), PJs (Aug 23, 2025), Scotty12 (Aug 15, 2019)
