Results 1 to 10 of 10
Thread: Surface Grinding Attachment
    Knife Maker
    JKeetonKnives's Avatar
    Aug 2019
    Texas
    JKeetonKnives's Tools
    Cool Surface Grinding Attachment
    As a knife maker, I love having flat pieces to work with. Makes my life way easier. In this video we will be replicating a common design that was first pioneered by Travis Wuertz. The Parts list and some drawings are in the description of the video.
    Full Build Video:
    J. Keeton
    "RedBeardOps" on both Youtube and Instagram
    Youtube: https://www.youtube.com/redbeardops
    Instagram: https://www.instagram.com/redbeardops/
  2. The Following 19 Users Say Thank You to JKeetonKnives For This Useful Post:
    asterix (May 24, 2025), Canyonman44 (Feb 15, 2020), Carnel (Feb 11, 2020), emu roo (Jan 1, 2026), GedB (Feb 15, 2020), high-side (Feb 15, 2020), Inner (Feb 11, 2020), Jon (Feb 10, 2020), kboy0076 (Dec 8, 2023), Lee Bell (Feb 14, 2020), Markdg (Feb 10, 2020), Moby Duck (Feb 16, 2020), rlm98253 (Feb 10, 2020), Scotsman Hosie (Feb 15, 2020), Sleykin (Feb 10, 2020), Sprig1 (Feb 11, 2020), tatoga (May 24, 2025), Tonyg (Feb 17, 2020), will52100 (Feb 10, 2020)
    Thanks JKeetonKnives! We've added your Surface Grinding Attachment to our Belt Sanders and Grinders category,
    as well as to your builder page: JKeetonKnives's Homemade Tools. Your receipt:
    Knife Maker
    Aug 2019
    Texas
    Quote Originally Posted by DIYer View Post
    <div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-surface-grinding-attachment"> <img src="/uploads/229553/homemade-surface-grinding-attachment.png"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-surface-grinding-attachment">Surface Grinding Attachment</a> <span> by <a href="https://www.homemadetools.net/builder/JKeetonKnives">JKeetonKnives</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/grinder'>grinder</a>, <a href='https://www.homemadetools.net/tag/surface'>surface</a> </div> </div> </div> </div>
    Thank you sir! Cheers
    J. Keeton
  6. The Following User Says Thank You to JKeetonKnives For This Useful Post:
    DanCom's Avatar
    Really good video. Well done.
    Knife Maker
    Aug 2019
    Texas
    Thank you very much Dan!
    J. Keeton
  9. The Following User Says Thank You to JKeetonKnives For This Useful Post:
  10. #6
    Congratulations JKeetonKnives - your Surface Grinding Attachment is the Homemade Tool of the Week!
    Good week with strong tools, but this was a clever addition, and a solid video - just when I thought we'd had our fill of homemade belt grinders!
    Some more nice builds from this week:
    Paint Drip Catcher by mklotz
    Marking Gauge by Christofix
    Bench Vise by meanwhileinthegarage
    Rivet Cutting Tool by thehomeengineer
    Custom Washer Fixture by rgsparber
    Broken Tap Removal Method by shopandmath
    Wire Bender by rgsparber
    Heading Anvil by Philip Davies
    Keyway Cutting Attachment by bouboulas
    Router Table by Make Things
    Compact Dust Collector by Sam's Workshop Diary
    Mobile Parts Drying Rack by bobs409
    Welding Table by Kwandotechnic
    Drill Sharpener Spindle Modification by metric_taper
    Knife Grinder by Mr.DK DIY
    CNC Router by buddyman100
    Table Saw Miter Jig by Didpoolhall
    JKeetonKnives - we've added your tool entry to our All Homemade Tool of the Week winners post. And, you'll now notice the wrench-on-pedestal award in the awards showcase in your postbit, visible beneath your username:
    You'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and award choice and I'll get it sent over right away.
    Nice work!
  11. The Following 2 Users Say Thank You to Jon For This Useful Post:
    emu roo (Jan 1, 2026), JKeetonKnives (Feb 14, 2020)
  12. #7
    Knife Maker
    Aug 2019
    Texas
    Heck yeah! Thank you! Really glad yall liked this one.
    J. Keeton
  13. The Following User Says Thank You to JKeetonKnives For This Useful Post:
  14. #8
    Knife Maker
    Aug 2019
    Texas
    Hey guys, I wanted to put this here as a follow-up if anyone happens to find this thread in the future. The SGA has been working great for me since February! THis update video has some tips and tricks on how to use your SGA if you're going to build one.
    Cheers!
    J. Keeton
  15. The Following 5 Users Say Thank You to JKeetonKnives For This Useful Post:
    emu roo (Jan 1, 2026), high-side (Jun 11, 2020), Jon (Jun 8, 2020), Tonyg (Jun 9, 2020), will52100 (Jun 8, 2020)
  16. #9
    Supporting Member CharlesWaugh's Avatar
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    Way cool!
    A thought on the adjusting knob:
    Use a differential screw.
    You can take a 3/8-24 screw, thread it through a block, and have a 1/4-28 step-down on the end that threads into the plate holding your magnet.
    One full turn of the screw = (1/24) - (1/28) Inches, or .0416 - .0357 = .0059"
    I have an old block plane with a differential screw on it and it's really nice for tweaking the cut a tiny tiny amount.
    Of course, if you can cut your own screws, you can make the final amount be ultra-tiny.
    Another way to get finer movement is to use a lever action to press on the magnet plate, using a spring to pre-load it back against the lever.
    Your adjusting screw pushes on one end of the lever, which is pivoted (say) 5" away with a 1" extension past the fulcrum/pivot point. This gives a 5:1 reduction in movement. So, a 1/4-20 screw (.050" per turn) will make a .010" movement.
    Of course, your total movement is then restricted, so you'll need to add a rough-adjust slide to this structure so you can get close the right measurement, then use the fine-adjust to do the final moves during grinding.
    Just some ideas to keep you up at night!
    Charles Waugh
    www.charleswaugh.com
    "Any tool is just a kit, to be modified as needed for the job at hand"
  17. The Following 2 Users Say Thank You to CharlesWaugh For This Useful Post:
    emu roo (Jan 1, 2026), JKeetonKnives (Jun 9, 2020)
  18. #10
    Knife Maker
    Aug 2019
    Texas
    Another Upgrade peeps:
    Download plans for belt sanders and grinders.
    J. Keeton
  19. The Following User Says Thank You to JKeetonKnives For This Useful Post:
