Trying to build a swaging tool from a Harbor Freight 24" bolt cutter. Need to know the dimensions for the swager opening to crimp 1/8" to 1/4" wire rope cable ferrules. Any information would be appreciated. Larry
Sounds like a good idea, but I seriously doubt if a HF bolt cutter is strong enough to do that swagging. I bought a set to cut 3/8" rebar. The handles are so springy, it is difficult to get enough force to cut. After struggling to get through 3 or 4 cuts, the blades had big gouges and would no longer cut. I realize you are probably going to make your own swagging dies. Just saying the basic tool itself is not really very strong. Of course there is the warranty, they took them back with no problem.
Be sure to save your receipt!!!!
Thanks for the input, hemmjo. Perhaps swager is not the best name for it, and maybe just "crimper" would be more appropriate. What I'd like to try to make is something like the one Home Depot sells for crimping small aluminum ferrules for 1/8" or so wire rope(nothing heavy duty). Following is a picture of one. I'd just like to know what the hole diameters are here so I can cut or grind an opening that size into the jaws. If this is a 14" swager, the jaws are probably around 3" long, and it seems like the biggest hole is around 1/2 inch. And, you're certainly right about cutting rebar with these. I have both a 24" and a 48" bolt cutter and even with the 48" it's not a piece of cake. You still have to press hard.
It depends if you want to make a fixture mounted on the bench top or portable, bench top would be able to be built of a more powerful style from heavy gauge steel. With that in mind, the principle of the conventional 'Hold down clamp' which when applied, will multiply up to possibly 10 times the amount of pressure required to actuate the lever, and as long as you harden your dies, would be a fast and repetitive action and easy to operate. Just my thoughts on this problem.
Converting a bolt cutter to a crimping tool, sure, why not. Try to copy the dimensions of an existing crimper. When cutting the crimping notches, grind them, do not use a torch or plasma. Grind slowly, you want to keep the heat out of the jaws. No more than 400 or 500 degrees F. 400 the metal can turn a light yellow color. Put a nice radius on all your crimping edges, you don't want to cut the aluminum, you want to squish it. If the handles bend reinforce them before you turn them into a banana. You should have plenty of power to crush hollow soft aluminum of 1/2 inch? diameter. It's great fun to modify an existing tool, cheaper, too.
There are currently 36 users browsing this thread. (0 members and 36 guests)
