Results 1 to 8 of 8
Thread: Table saw blade angle setting tool
    Glendale, California
    tony_912's Tools
    I made this jig for measuring table saw blade angles accurately, but it proved to be best at setting it to 90°. I love how accurate it is and how easy to use.
  2. The Following 4 Users Say Thank You to tony_912 For This Useful Post:
    Jon (Feb 24, 2016), kbalch (Feb 25, 2016), Paul Jones (Feb 24, 2016), PJs (Feb 25, 2016)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Nice jig. Setting the correct and exact angle on the table saw takes some practice. By the way my favorite table saw blade is the Freud LU87R009 9-Inch 22 Tooth ATB Thin Kerf Ripping Saw Blade with PermaShield Coating. I cut a lot of hardwoods (mahogany, oak and a very hard birch) and this blade does a superior job in ripping with no burn marks and still produces a glass-like cross cut finish. The 9" model has a very thin kerf and is pretensioned for truer cuts under heavy loads. I use it for all types of cuts. Thanks for the video.
  4. The Following User Says Thank You to Paul Jones For This Useful Post:
    tony_912 (Feb 24, 2016)
    Thanks tony_912! We've added your Table Saw Blade Angle Setting Tool to our Angle Guides and Try Squares category, as well as to your builder page: tony_912's Homemade Tools. Your receipt:
    Oct 2013
    just a post to stay an active lurker
    Welcome to HomemadeTools.net bstromb. Feel free to lurk away
    This is very similar to the technique that machinists use to test the squareness of cylinder squares and machinists' squares.
    A steel base with a protruding foot (analogous to the screws) has a vertical beam that carries a DTI (Dial Test Indicator). On a granite surface plate the foot is pressed against the cylinder square and the DTI reading noted. Then this action is repeated on other points around the square circumference. Adjustments are made until all readings coincide. Note that the beam need not be precisely orthogonal to the base; it only has to be rigid so the point of the DTI remains the same distance from the foot.
  9. #7
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Hi bstromb,
    Welcome!
    What sort of homemade tools do you prefer to lurk on?
    Ken
  10. #8
    Dec 2015
    bbutcher85's Tools
    Quote Originally Posted by tony_912 View Post
    I can't find the photos except the close-up showing the tip of the indicator.
