Thread: Tapping fixture and auto reversing tapping head
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    This is an adjustable tapping fixture, which I made to use in conjunction with an auto reversing tapping head. The idea is to set the work-piece so it is supported and held in the fixture but is easily slid within the fixture. The fixture is then, positioned under the drill spindle and bolted to the table and each hole in that plain, can be tapped. (The video should clarify this).
    The clutch on the tapping head can be set to avoid breakage. To reverse the direction of the tapping head you simply lift the quill upwards, which reverses the direction of the cutting tool without having to switch the machine off or change the motor direction. The hexagon bar acts as a stop to prevent the main body of the tapping head from rotating.
ID:	23961 setting the work-piece in fixture
    The Home Engineer
  2. The Following 13 Users Say Thank You to thehomeengineer For This Useful Post:
    Bobinwa (Jun 17, 2018), emu roo (Mar 26, 2025), HobieDave (Mar 27, 2020), jjr2001 (Mar 1, 2019), johnsmachines (Oct 3, 2018), Jon (May 29, 2018), LMMasterMariner (Jun 2, 2018), PJs (May 31, 2018), rlm98253 (May 29, 2018), rossbotics (May 29, 2018), Scotsman Hosie (Apr 12, 2019), Seedtick (May 29, 2018), Toolmaker51 (May 30, 2018)
