Results 1 to 8 of 8
Thread: Thermal Forming PVC Pipe
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I stumbled on a few YouTube videos of people using heat to form PVC pipe. Although I don't have a problem that would be solved with this technology at the moment, that didn't stop me. It was fun to see what could be done with some scrap PVC pipe and my heat gun.
    http://rick.sparber.org/PVCTF.pdf
    Thanks,
    Rick
    Rick
  2. The Following 2 Users Say Thank You to rgsparber For This Useful Post:
    jjr2001 (Jan 15, 2017), mklotz (Jan 15, 2017)
    I just let my mind wander (not that I can prevent it doing that) and came up with some silly ideas. Maybe they'll strike a chord in your mind and lead to visualizing something truly useful.
    specialized nozzles for your shop vac - e.g. a T-shaped T-slot cleaner
    artistically shaped plant trellis - fine holes drilled in pipe to "artistically" water the plant
    roadways for a marble machine
    miniature funnels for filling small containers
  4. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    jjr2001 (Jan 15, 2017), PJs (Jan 15, 2017)
    Here is something I've done many times
    cut a 1/2 or 3/4" wide piece off a thin wall PVC, plex poly, or most amy other plastic tubing or pipe then split it and make a flat strip out if it the heat and bend one end about 1/2 to 3/4" as needed to a 90° bend then heat ten remaining body and wrap it around whatever diameter piece you need to make a clamp out of it bringing the 2 ends together forming a flat which you then drill a hole in it for a bolt
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Excellent Ideas Marv and Frank! Thanks.
    Mark Twain
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Marv,
    All good ideas. I have updated the article to try some out.
    Thanks!
    Rick
    Rick
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Frank,
    I made one of your straps and it worked perfectly. Thanks for the great idea. It is now in the article.
    Rick
    Rick
  10. #7
    Thanks Rick! We've added your PVC Pipe Forming Method to our
    Heating and Cooling
    category, as well as to your builder page: Rick's Homemade Tools. Your receipt:
  11. #8
    Thanks Rick! We've added your PVC Clamp to our Clamps category, as well as to your builder page: Rick's Homemade Tools. Your receipt:
