Results 1 to 10 of 13
Thread: Thread checking
    Thread checking
    I suppose this is more a hint than a tool but it's still a useful device that should be valuable to novice machinists.
    In modelmaking one makes a lot of threaded parts and, as a consequence, acquires a large collection of taps and dies. Whenever I encounter a new thread and need to buy threading tackle, I buy two taps and a die for the required size. I use the tap to make a nut and then adjust the die to make a stud that is a smooth running fit in the nut. These test pieces go in a pill vial, along with the taps and dies. The cap of the vial is Sharpie-marked (black for inferial and red for metric) with the thread designation, and tap drill for 65% thread depth (makes threading easier and reduces tap breakage). A large 'LH' in green is added for left-hand taps and dies.
    If one encounters an unidentified thread, there are numerous ways to identify it. If it's a male bolt/screw, thread checker plates, e.g.,
    Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
    can work but they often don't cover the smaller or seldom-used sizes and, more importantly, are impossible to use if the threaded stud is attached to machinery that blocks the rotation of the checker. Nut and bolt checkers, e.g.,
    Nut & Bolt Thread Checker (Inch & Metric) - Tap And Die Sets - Amazon.com
    suffer similarly in size coverage.
    I could dig my test pieces out of their vials and use them as checks but that's too tedious for me. So I put together a plate with a nut and bolt sample of all the sizes I encounter...
    In the case of bolts not in my collection (e.g., the very uncommon 5-44), I simply make another set of checkers using the tap and die in my collection. Since I have a fairly large fastener collection, this happens very infrequently.
    A personalized set like this covers several points. Any nut or bolt can be removed and taken to the questioned thread for checking plus its presence in the set proves that I have the necessary threading tackle to make whatever is required, male or female.
    Make yourself one of these; it will save you both time and aggravation.
  2. The Following 12 Users Say Thank You to mklotz For This Useful Post:
    baja (Aug 22, 2019), jackman (Jul 29, 2017), Jon (May 18, 2016), kboy0076 (Jan 2, 2024), lazarus (Jun 3, 2016), ncollar (May 19, 2016), oldpastit (Aug 22, 2019), Paul Jones (May 21, 2016), paul_j (Jan 3, 2026), rlm98253 (Dec 10, 2017), Seedtick (May 19, 2016), Shaper (Dec 11, 2017)
