Wednesday I started to move some dirt to fill in the low spot in the corner of the shop but before I could do that I had to remove the fork carriage and install the loader bucket. Sometimes this is a mere 30 to 45 minute job or even less but other times things just never seem to fall in place as they ordinarily would. Most of this is my fault for getting in a rush to do the change over or where I had decided to do it. This was one of those times I had moved the bucket with the forks and did not have it sitting level after removing the fork carriage then trying to align the loader arms with the pin locations it took the better part of an hour to get the change over accomplished then even more time to locate 2 of the snap rings in the sand and grass burs that had gone ballistic when I removed them.
Anyway I moved a dozen of so loads of dirt to fill in a low spot to make it easier for me to enter the shop from an area I normally didn't go through then I mined a large pile of the select fill. Things were going fine running up and down the haul road a little too fast at times I guess because the backhoe was bouncing sometimes
The used tire I had installed on the rear a few months ago was a lower pressure rating than the original and the rubber was old and probably well beyond an age for tubeless mounting. I entered the area where I had the fill mounded up at a wrong angle ran over a hard out cropping not sharp just a large bump that was when the dreaded hissing sound started grabbing a load of select fill I headed back up the hill to the shop and just barely made it to be able to dump before the tire went completely flat.
OK I have a second tire I'll just install it I thought but I will tube it in an attempt to stave off rupturing the inner bladder of the next tire.
So that night I ordered a new tube which was not going to arrive until next Tuesday. OK fine I will work on other projects then this time take the tire and rim to my tire man and let him wrestle the change.
Well the tube arrived yesterday afternoon late So once again I decided not to wait until I could load everything up and take it to town. half the work of changing the tire would be removing the rim from the machine and re installing it anyway.
But since I already had it off the backhoe laying on the ground and a new tube in hand and it being Saturday the tire guy wouldn't be at work until Monday I broke it down and started installing the equally old replacement tire.
Inspector Whitey wondering where her new favorite sleeping spot had gone
way too much 4 legged help
