Results 1 to 5 of 5
Thread: Tools for sandcasting
    Supporting Member Workshopshed's Avatar
    Mar 2013
    Suffolk, UK
    Workshopshed's Tools
    From left to right, crucible lifting tongs, regular tongs for coal and metal loading, pouring shank, skimming tool.
    Workshopshed: Red Hot - Casting
    Andy from Workshopshed
    "Making and repairing things in a shed at the bottom of the garden"
    workshopshed.com
  2. The Following 3 Users Say Thank You to Workshopshed For This Useful Post:
    Jon (Mar 6, 2013), kbalch (Mar 6, 2013), Paul Jones (Nov 2, 2015)
    Thanks Workshopshed! These have been added to our Metalworking category, and to your homemade tools page: Workshopshed's Homemade Tools. Your receipt:
    Jun 2014
    well thanks for sharing have you any layouts i could have so i can make some up for myself?
    Mar 2013
    Suffolk, UK
    I don't have plans or dimension for these. They were measured up against my crucible.
    The lifting tongs were made from a pair of domestic coal tongs with the faces ground down and drilled. The jaws are bent pieces of "repair plate" which are pop riveted onto them. These were just a convenient length and need to be long enough to stop the cruicble tilting whilst it is being lifted.
    The pouring shank was made from a fire poker that was hacksawn down the end and then heated in the furnace till red and bent into shape with a large pair of pliers. You need to ensure that the prongs are longer enough to support the crucible, for large sized crucibles I'd recommend making a complete loop and welding the ends together. You can then place that on the floor and lower the crucible onto it with the lifting tongs.
    The skimmer was a bent barman's spoon with a hand turned wooden handle.
    workshopshed.com
    Jun 2014
    thanks for that i know what i'm doing this weekend!!!! meantime back to making up some mockups of some lathe tools before i do the real ones. Thanks again.
