Results 1 to 8 of 8
Thread: Trailer Electrical Tester
    Lake Tahoe
    IntheGroove's Tools
    I needed a tester for working on electric parts on trailers. I didn't care for the commercially available units so I made one with parts I had on hand. Inside the box are two automatic-reset circuit breakers, one for the lights and one for the brakes. A 30 amp relay for the brakes. A solid state flasher. I mounted a voltmeter and a amp meter. The voltmeter will check the test battery or the battery on the trailer. The amp meter is for checking the brake coils.
    Trailer Electrical Tester-img_1723.jpg Trailer Electrical Tester-img_1725.jpg Trailer Electrical Tester-img_1724.jpg
    It will test all electric functions of a trailer, Lights, Brakes and Battery
    I made a 25 foot extension for the trailer that can also be used on the tow vehicle with the plug-in tester so I can test from the driver's seat or under the hood where the fuses and relays generally are.
    Trailer Electrical Tester-img_1915.jpg Trailer Electrical Tester-img_1722.jpg
    Most trailers don't have backup lights put some trailers with surge brakes use a solenoid in reverse to stop the brakes from engaging, also will power-up backup cameras.
    Trailer Electrical Tester-img_1728.jpg Trailer Electrical Tester-img_1726.jpg Trailer Electrical Tester-img_1916.jpg
  2. The Following 14 Users Say Thank You to IntheGroove For This Useful Post:
    almarghi (Dec 24, 2022), baja (Feb 10, 2021), clydeman (Dec 23, 2022), EnginePaul (Feb 10, 2021), hemmjo (Feb 10, 2021), Jon (Feb 10, 2021), katy (Feb 10, 2021), mlcohen987 (May 10, 2021), rlm98253 (Feb 9, 2021), Scotsman Hosie (Feb 13, 2021), Sleykin (Jan 1, 2023), thevillageinn (Feb 9, 2021), Toolmaker51 (Feb 9, 2021), will52100 (Feb 9, 2021)
    Thanks IntheGroove! We've added your Trailer Circuit Tester to our Electrical category,
    as well as to your builder page: IntheGroove's Homemade Tools. Your receipt:
    IntheGroove (Feb 9, 2021), ztoolman (Feb 10, 2021)
    hemmjo's Tools
    It is nice to have all the testing required in one package.
    Jan 2019
    Would you share the schematic?
    Lake Tahoe
    IntheGroove's Tools
    I'll try to draw a schematic but it might take longer to do than it did to build the thing...
    Supporting Member odd one's Avatar
    Apr 2020
    WNC
    odd one's Tools
    Very nice. There are commercial units out there like that, but they are big bucks.
  9. #7
    mccwho's Avatar
    Jan 2020
    Wink
    Quote Originally Posted by odd one View Post
    That's a fantastic job. All that work is a lot of time spent figuring all that out. We would be greatly appreciative of schematics when you have time to do it. That would be a big help!
  10. #8
    Lake Tahoe
    IntheGroove's Tools
    There was a little mishap with the tester so I am rebuilding it. Since it's apart I will draw out a schematic...
    Trailer Electrical Tester-img_4354.jpgClick image for larger version.
  11. The Following 4 Users Say Thank You to IntheGroove For This Useful Post:
    dgbreggin (Mar 27, 2026), ductape (Jan 9, 2026), mccwho (Jan 8, 2026), odd one (Jan 8, 2026)
