Results 1 to 8 of 8
Thread: - Ultimate circle cutting guide-
  1. #3
    Jyväskylä Finland
    Tuomas's Tools
    Plans:
    Arms can be lock to set distance by tightening M5 screws on the sides.
    6mm rods works as an arms. These rods go trough the blocks made from 20 x 20mm bar.
    Holes where these rods goes trough the bar. Are located so, that holes hit to the 10mm holes of the swiveling axle. 10mm axle is grooved from this section, around the axle, from both ends.
    I made those grooves with dremel using tungsten carbide cutter.
    These 6mm axle leans to the grooves, this locks the swiveling head sideways, and keeps it centered with the bearings, that are located to the center of the suction cup.
    More info at the plans itself.
    Ask if you have questions.
    Thank you for checking this out.
  2. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
    Scotsman Hosie (May 14, 2019), wgfabrication (Jun 6, 2020)
