Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Universal Grinder Power Feed xy table power feed
    Oct 2012
    There is also a thing called a dog clutch that works the same but much easier. Here is a link for one maybe it will give you some food for thought.
    A Dog Clutch for the MiniLathe
    Nelson
  2. The Following 3 Users Say Thank You to ncollar For This Useful Post:
    Home-PC (Jul 13, 2022), jjr2001 (May 10, 2018), Paul Jones (May 12, 2018)
  3. #12
    Mar 2018
    New England, USA
    threesixesinarow's Tools
    My mill has a power feed with a friction clutch with cork gasket material glued to the worm gear - just turn the doorknob to engage or disengage it.
  4. The Following 3 Users Say Thank You to threesixesinarow For This Useful Post:
    Home-PC (Jul 13, 2022), Paul Jones (May 12, 2018), PJs (Sep 13, 2018)
  5. #13
    Oct 2012
    Quote Originally Posted by threesixesinarow View Post
    very interesting
    Nelson
  6. #14
    Dec 2016
    Ralphxyz's Tools
    yeah I'd like to see more detail, I need to do my mill someday.
  7. The Following 2 Users Say Thank You to Ralphxyz For This Useful Post:
    Paul Jones (May 12, 2018), PJs (May 11, 2018)
  8. #15
    jjr2001's Tools
    Now I am liking that. I saw some round brake coils on the net somewhere that would be a great fit for my little power feed. Now to just find them.
    Cheers JR
  9. The Following 2 Users Say Thank You to jjr2001 For This Useful Post:
  10. #16
    Mar 2018
    New England, USA
    I don’t have an inside photo but it’s simple.
    I removed the shaft of the wiper motor worm gear, the cross hatched part in the middle of the drawing, and bored out its center to run on a shoulder on the inboard one of two steel clutch plates that take the place of the keyed on right handwheel on the end of the feed screw. I tapped the hollow steel shaft of the doorknob to take the place of the handwheel retaining nut, and stuck a coil spring inside it to press the end of the feed screw so they turn together.
    Tightening the knob presses the clutch plates together against the cork sheets glued to the faces of the worm gear and the cork has enough spring to push the plates apart when the pressure is removed. The clutch can be set tight or loose enough to slip but only by feel.
    It looks like your car seat motor could be modified to work the same way.
  11. The Following 3 Users Say Thank You to threesixesinarow For This Useful Post:
    jjr2001 (May 23, 2018), Paul Jones (May 12, 2018), PJs (May 13, 2018)
  12. #17
    Dec 2016
    Ralphxyz's Tools
    Thanks, I almost understand once I have a motor in my hand it should come together.
    Ralph
