Originally Posted by
drmico60
The problem with stamping uniformly is not solved by having a consistent pressure/impact. This is because each letter/number has a different total line length and therefore requires a different pressure. For example the length of the lines making up the letter H is nearly three times the length of the lines making up the letter I so to stamp an H needs nearly three times the pressure to get the same indent depth as stamping a letter I. Each letter is different so there require different pressure on the stamp.
Mike
