Results 1 to 10 of 13
Thread: V Block with Clamps
  1. #7
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Hi Garage Nut, Thank you for your interest in my V blocks.
    Disclaimer:
    Always be sure when working with machinery to be careful and follow all the safety rules during operations.
    If you feel unqualified get a skilled machinist to help you with the project.
    the measurement for the block will be determined by the internal size of your square tube.
    1. mark a center line on a squared block on three sides, using blue or red marker dye.
    2.mark a v shape 45* on the center line on the front and back .with the center line on the bottom of the v.
    3.on the top of the square, on the center line, drill 1/4 inch holes all along the line to remove as much metal as you can, staying inside the v lines on the front and back of the block.
    4. Mill on a 45* table to cut the rest of the metal away that you could not get with the drilling. Or use a hand file if you don't have a mill.
    5. The side slots are done in the same manner as above except marking a square instead of a v shape drill as required.
    6. Cut the square tubing twice on one side to what ever size you cut the slots on the side of the block and file to fit.
    the answer to your last question is yes.
    Note. you could use a end mill to cut the whole thing out but end mills are expensive so I use drill bits to save wear and tare on the end mills. Drill bits are cheep.
    Have fun and enjoy...Cap
    If you feel unqualified get a skilled machinist to help you with the project. at your own risk.
    :O)Click image for larger version.
ID:	20787Click image for larger version.
  2. The Following 3 Users Say Thank You to Captainleeward For This Useful Post:
    emu roo (Oct 16, 2025), garage nut (Dec 4, 2017), ncollar (Apr 24, 2018)
