Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: Variable Frequency Drive for a larger factory fan
    Supporting Member chy_farm's Avatar
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Last year we had a very hot Summer and Autumn so had a presumption that we should need a very big fan in our shed to get our job easier this year.
    This motivation gave me a way to build a single phase Variable Frequency Drive for a bigger fan motor!
    Fortunately or unfortunately we have cool Summer now, so not yet get a new big fan yet, nor have a chance to run this VFD...
  2. The Following 2 Users Say Thank You to chy_farm For This Useful Post:
    Jon (Jul 31, 2020), nova_robotics (Jul 30, 2020)
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Inside: Triangle and rectangle generators are analogue unit.
  4. The Following User Says Thank You to chy_farm For This Useful Post:
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Started from these;
    Making shifts to the frequency is to be done with a couple of white dials, an obsolete analogue way.
    Chy
  6. The Following User Says Thank You to chy_farm For This Useful Post:
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    But on the way of assembling I found this handmade case was a tad small, so added some more rooms ;
    Main power board with magnetic contactor and a transformer;
    Placed a noise filter right after the main contactor;
    Temperature sensors are placed onto five different part,
    1: Bridge diode (50A),
    2: Short cut unit,
    3: Isolated Gate Bipolar Transistor unit,
    4: High speed diodes for return current re-circulation unit,
    5: Double 2mH filter coils right before the output terminal;
    Output frequency monitor;
    Output current monitor, and its detector (HAS-50);
    Variable Frequency Drive for a larger factory fan-has_50-s_current_transducerjpg.jpg
    Chy
  8. The Following User Says Thank You to chy_farm For This Useful Post:
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Schematic for power units is;
    Chy
    please note there may be a wrong design in above drawing.
  10. The Following 2 Users Say Thank You to chy_farm For This Useful Post:
    Carnel (Jul 31, 2020), nova_robotics (Jul 30, 2020)
  11. #6
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    A couple of logic units of this type is known as noise-fragile to electro-magnetic noises. This part was one of the complexities to me.
    Units in the right half (marked yellow) are electrically shielded with copper plate around them, they are a triangle wave generator and a wave form comparator, and a sine wave generator.
    These in the left half are also shielded with so called shield wire (black wires), they make up a Pulse Width Modulation logic unit.
    Chy
  12. The Following User Says Thank You to chy_farm For This Useful Post:
  13. #7
    Sep 2018
    nova_robotics's Tools
    That's great. Well done.
    Why three Arduinos?
  14. The Following User Says Thank You to nova_robotics For This Useful Post:
    chy_farm (Jul 30, 2020)
  15. #8
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Good morning Nova, Why? ,,, only because I did not know other ways, lol. Do you make them in one Uno?
    Chy
    p.s. Glad to know you are a specialist of robotics, Nova!
  16. #9
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    The logic unit needs a delay-time-unit for one of the safety purposes;
    This unit is not yet given the noise shield.
    The delays are confirmed with oscilloscope views;
    Chy
  17. #10
    trigger's Avatar
    Jun 2018
    Does the breadboard not contribute to rf noise ?Once the design goes to PCB there should not be so much interference.
