Results 1 to 6 of 6
Thread: Very first attempt at Mig welding : A T allen Key
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi,
    I have just purchased a new MIG (no gas) welder, and I have just tried it for the very first time.
    And with my first two centimeters of MIG welded joint, I made a new tool :
    I just took a couple of these redundant Allen keys often delivered with various purchased things to be mounted by the user, and welded them together in a T shape. I then cut the upper one, at the elbow.
    Here it is, a strong T handle, keeping the possibility to use the three hex tips !
    I've never been a good welder, I used to "arc" weld with an inverter, but for a first attempt, that's not so bad.
    I think it is here that I saw for the first time someone using a MIG welder and It seemed so easy that I wanted to try.
    I ended up finding this no gas setup which works pretty well for a small use like what I need.
    The advantages are really numerous :
    - Much easier to weld than arc welding
    - Joint much more clean
    - More ready to use
    - Setup quick and easy (for that model)
    So, I 'm quite happy with this new welder, so far ...
    Here is the welder :
    GYS SmartMig 110 (No Gas, welds steel only)
    Could anyone tell me why it says only steel on the pack ? The wire is 0.9, why could'nt I weld, even with a reduced capacity some stainless steel or aluminium ?
    Can I also weld cast-iron with it ?
    Cheers,
    Christophe
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 2 Users Say Thank You to Christophe Mineau For This Useful Post:
    kbalch (May 15, 2015), Paul Jones (May 15, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Christophe! I've added your T-Handle Allen Wrench to our Welding category, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    Good job on that T-handled hex key, Christophe. With your creativity, I look forward to what you're going to do with your new toy.
    From luthiery to metalworking, please send some of your talent my way Christophe.
    Al
    Dec 2013
    welder
    well done , on your first time , as for alloy you need an AC welder ...you have a DC welder , also you need a shielding gas of argon for alloy , ...
    cheers
    Jul 2014
    France, Brittany !
    Thanks stumpy,
    And for stainless steel, is it the same as for alloy ?
    Thanks for the piece of advice.
    Christophe
    Cheers !
    Christophe
