Simple attachment to my vise.
For bending and straightening things.
Attachment 21792
Video:
https://www.youtube.com/watch?v=TMLUoHQjwus
Attachment 21792
Video:
Due to the height of the pivot center above the vice jaw you have a predictable bend radius which would be great for bending 1/8" thick aluminum. I don't know how many guys I have encountered over the years who had trouble when trying to bend thicker alum.because their box breaks or folding type breaks had the pivot almost on direct center of the bend which would cause the alum. to crack unless they annealed it first
I like your simple little attachment mostly for this reason
I like the "Insert clickbait here" video title.
13 Ways to Bend Metal - you won't believe #7!
1 Weird Trick for Bending Metal!
Cure Cancer by Bending it in a Vise!
Pretty neat! I never thought about using a vise in that way, but this is obviously useful and easy to implement tool.
So simple but very effective.
Can think of so many problems I've had that this will solve. Don't understand why my brain didn't come up with this. Certainly will make one.
Thanks Tuomas! We've added your Vise Mounted Bender to our Metalworking category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-vise-mounted-bender"> <img src="/uploads/209625/homemade-vise-mounted-bender.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-vise-mounted-bender">Vise Mounted Bender</a> <span> by <a href="http://www.homemadetools.net/builder/Tuomas">Tuomas</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/bender'>bender</a> </div> </div> </div> </div>
Improvement nro 1
Height adjusted front jaw. Gives more support when filing, and allows better view to the object. Specially with thin materials.
Allows to adjust bending radius unportable.
Attachment 21877
Video coming later.
One more add...
Attachment 22062
Now i can adjust the position of the point that leans against workpiece. This gives more symmetrical result.
Attachment 22063
Wow Tuomas...you did it with the bend Radii. Amazing all the things you come up with to make life easier! I'm thinking this tool should make toast in the morning and french fries in the evening...watcha think! ~¿@ You always amaze me with your inventiveness, Thank YOU!
:thumbsup::clapping::hattip:
Personally I think your vice bender is pretty Versatile & complete but not sure I have the inventiveness you have for Optional tool uses. The idea of creating bend radii for small projects really appealed to me and think you nailed it. Perhaps after using it some more something will come up that may warrant further options. Great Job Buddy! :hattip:
Sounds interesting. Whenever you get time! Thanks Tuomas.
