Results 1 to 4 of 4
Thread: Weir effect on river topography demonstrated - GIF
Hybrid View
    Weir or low head dam effect on river topography demonstrated.
    Geology stream table - GIF
    Dam breach in China - GIF
    Flushing silt from a dam - GIF
    Dam spill gate failure - GIF
    Lake Berryessa Glory Hole spillway drain - GIF
  2. The Following 8 Users Say Thank You to Altair For This Useful Post:
    asterix (Apr 29, 2025), clydeman (Apr 29, 2025), durrelltn (Jul 22, 2022), EnginePaul (Jul 21, 2022), mwmkravchenko (Jul 21, 2022), nova_robotics (Jul 21, 2022), Ralphxyz (Jul 24, 2022), Toolmaker51 (Jul 21, 2022)
    Not so effective in milling machines or lathes running steel, better in non-ferrous or plastics, but weirs are used exactly this way in coolant tanks, especially big rotary Blanchard and reciprocal grinders. Typically there are 3 'locks', flat panels stepped in height; some use one drawing from below against flotsam debris.
    A dream come true for every new shop-hand. . .
    Last edited by Toolmaker51; Jul 21, 2022 at 12:22 PM. Reason: 4th times the charm (one extra to make sure)
    Rikk's Avatar
    Nov 2018
    Rikk's Tools
    Man did I hate cleaning coolant tanks when I was running grinders... Especially on the machines that used oil rather than a water based coolant. I always took a change of clothes on those days.
    Learned as much machining possible, as quickly possible for same reason. First shop had big Blanchards and Thompsons; had to be 50 gallons plus. Water soluble fluid was mixed by a venturi drawing from barrel of concentrate. Not high on list of enjoyable tasks. Rotary grinders were used prepping compression molds; big surface area, always both sides, very flat but not much concern about specific thickness. Lots of goo in the tank.
  7. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Rikk (Jul 25, 2022)
