Results 1 to 7 of 7
Thread: Welding Fixture/Mini Positioner
    Supporting Member Carlos B's Avatar
    Canada
    Carlos B's Tools
    I built this fixture late last year after seeing the tip illustrated in the first pic. somewhere on the web.When I find large enough wing nuts I will change out the nuts that require the wrenches seen on the hooks. This will make set-up even faster than it already is. The fixture can rotate 360* in two planes to allow me to make flat welds when a position weld would challenge my welding abilities. The fixture is all built from pipe and pipe fittings except for the table which is a motor mount from a discarded motor stand. The last 3 pictures is an example of the quick set-up of a small angle frame for welding.
    Carlos
    From a popular rap: "If time is money then I need a loan."
    Carlos B,http://hobbyworkshopprojects.blogspot.com
  2. The Following 18 Users Say Thank You to Carlos B For This Useful Post:
    baja (Mar 21, 2020), billster (Mar 16, 2017), C-Bag (Mar 13, 2017), Duke_of_URL (Mar 20, 2020), emu roo (Sep 5, 2025), EnginePaul (Mar 20, 2020), JD62 (Mar 15, 2017), johncg (Nov 24, 2022), NortonDommi (Jun 17, 2018), oldcaptainrusty (Feb 7, 2018), Paul Jones (Mar 16, 2017), PJs (Sep 24, 2025), Quinton 357 (Mar 21, 2020), rlm98253 (Feb 5, 2018), rossbotics (Mar 14, 2017), sossol (Feb 9, 2018), tonyfoale (Mar 13, 2017), tuchie (Nov 24, 2022)
