Results 1 to 4 of 4
Thread: welding positioner, rotating table
    Feb 2013
    Poland
    radom's Tools
    I was thinking about building small bench type welding positioner for a long time but when I found this big lathe chuck for cheap I changed my design a bit
    I made the positioner that I can insert 80mm pipe through it, although chuck have through hole of 100mm
    this limitation is only because I already had the materials and could make bearing housings on my small lathe
    there is also a trust bearing directly under the face plate
    I mainly tig weld so the speed is quite slow around 1,2rpm max, it's 12v dc motor with pwm speed controller
    ideally you would have worm drive because it's self locking but I couldn't find one at the time, maybe I will change that in the future
    motor, sprocket and ground wire are isolated from the frame (small sprocket is mounted on nylon shaft)
ID:	1509Click image for larger version.
ID:	1510Click image for larger version.
ID:	1511Click image for larger version.
ID:	1512Click image for larger version.
ID:	1513Click image for larger version.
ID:	1515Click image for larger version.
  2. The Following 2 Users Say Thank You to radom For This Useful Post:
    kbalch (Mar 31, 2014), lanemfg (Mar 19, 2020)
