Results 1 to 6 of 6
Thread: Wire tie tool
    Wire tie tool
    Clamptite makes a neat tool for forming wire ties. It's function is described on their website...
    Buy ClampTite Tools and Wires
    [Be sure to watch the videos describing its use.]
    I had an application for such a tool but I really didn't want to lay out the $70 for what seems to me to be a pretty simple thing. So, muttering to myself "this is why I have a machine shop", I made my own...
    The body is half-inch 12L14, the screw is 1/4-28 and the pins are 3/32" roll pins. The tip has a shallow 1/16" wide slot milled into it to anchor the wire when making double wraps...
    Shown in the first picture is one of my uses for it - securing silicone aquarium air tubing to brass fittings with a double wrap of soft iron florist wire.
    If I were to use heavier wire such as safety wire, I would probably make a larger version of the tool but, for now, this one does what I need.
    Home Shop Freeware
  2. The Following 7 Users Say Thank You to mklotz For This Useful Post:
    DaveInPA (Sep 2, 2015), Jon (Sep 1, 2015), kbalch (Sep 1, 2015), lazarus (Jul 13, 2016), Paul Jones (Sep 14, 2015), PJs (Sep 2, 2015), Trojan Horse (Jul 4, 2017)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Marv! I've added your Wire Tie Tool to our Miscellaneous category, as well as to your builder page: mklotz's Homemade Tools. Your receipt:
    I saw one of these a couple years ago and thought it was neat so I also made one. It gets very little use, you can buy a lot of proper clamps for $70. Mine was made from a scrap of 4130 tubing with a mild steel point braised on. The slot was cut by hand with a dremal tool and 1/4" all thread with a wing nut and 2 roll pins finished it off. Fun to make.
    Ralph
  5. The Following User Says Thank You to Hooverra For This Useful Post:
    Dec 2015
    I built a similar tool, I copied the "Haywire" tool. I have only used it a couple times but plan on using it when I build a PVC greenhouse this summer.
    Supporting Member jotasierra's Avatar
    Sep 2015
    país Argentina, provincia de San Juan
    jotasierra's Tools
    Gracias por compartir, muy sencilla y util, muy bueno el video y las instrucciones, gracias otra vez.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    This works:
    Rick
  9. The Following 3 Users Say Thank You to rgsparber For This Useful Post:
    Christophe Mineau (Jul 5, 2017), johncg (Jun 18, 2022), wimton (Jun 21, 2022)
