Thanks tonyfoale! We've added your Caliper Modifications to our Measuring and Marking category,
My suggestion of using calipers for splinter extraction was meant for instances when tweezers aren't immediately to hand. You should have proper tweezers as well. Yes, surprisingly, many of the better are made in Pakistan. Amazon has a good selection.
A handy form, if you can find some, has tips shaped like the jaws of flush-cutting pliers. These push the skin down, exposing the tip of the splinter, which can be grasped with greater pressure because of the line contact of the tips. The tips of the caliper jaws mimic this form and that's what makes them an effective tool for the job.
Splinter removal tips are legion. One of my favorites is a technique for wooden splinters. Apply some wood glue to the affected area and let it dry. After it's dry pick it off the skin. If all goes well, the splinter will be glued to the blob of glue you removed.
Toolmaker51 (Nov 16, 2018)
olderdan (Nov 22, 2018)
Continuing on this theme of reverse engineering I have made another post about measuring the various radii on the crankcases. You can find that here Radius-gauge
I cut up a set of Harbor Freight $10.00 (with coupon ) 6" calipers to convert to DRO on tailstock of 7x10 mini lathe. Also soldered wires to use a AA battery plus a switch as the real cheap pnes never turn completely off (on/off switch only turns off display) Always wondered why battery life was so short
Don't make the same mistake that I did. When you close up a normal caliper, that is the reference to set zero. I cut all that off, and lost that zero, it is enough to just leave a small bit for zero contact. Easy when you are forewarned which I wasn't. All is not lost though, I can use the depth measuring stick to set zero, just not so convenient.
HobieDave (Mar 17, 2020)
crazypj (Jan 1, 2019)
