Many thanks for the comments and suggestion. I noticed that also, but I thought that I didn' tighten them enough. Will do as suggested. Thanks again.
That is indeed a very impressive project!!!!
As I was reading through the posts and comments, I have to share that this line in one of your responses really made me laugh...."Recirculating oil pump would be very nice addition to this project, but I wanted to make it simple."
These words specifically, "....but I wanted to make it simple.", really tickled my funny bone!!!! I am not positive but I think you flew past (or perhaps sailed in your case) simple long before you even started collecting all of the gears, and bearings, and racks, and keys, and oil sight glass, and bolts, and etc....
I hope you get my perspective on this!!
Awesome,
John
Thanks LMMasterMariner! We've added your External Lathe Gearbox to our Lathes category,
as well as to your builder page: LMMasterMariner's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-external-lathe-gearbox"> <img src="/uploads/213419/homemade-external-lathe-gearbox.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-external-lathe-gearbox">External Lathe Gearbox</a> <span> by <a href="http://www.homemadetools.net/builder/LMMasterMariner">LMMasterMariner</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='http://www.homemadetools.net/tag/gears'>gears</a> </div> </div> </div> </div>
Hi LMMasterMariner
Great build and the video was easy watching and interesting. Got my vote for tool of the week this is an exceptional add-on to your lathe and I congratulate you on your design and workmanship.
First class.
The Home Engineer
couple of ideas which I abandoned in order to make it simple:
12 speeds instead of 18 speeds
different selector handles and detents. simply bought three M18 bolts and nuts and made different, much simpler detent mechanism, as I knew that I wouldn't have time to complete it as originally planned.
couple of drawings attached.
Wow! Excellent presentation (thank you) and nicely engineered. Definitely Tool-of-the-week candidate! Was that disk brake OEM or did you add it?
More about disk brake can be found at http://www.homemadetools.net/forum/l...ck-brake-61437 and http://www.homemadetools.net/forum/l...-fixture-61693
Best regards
LMMasterMariner
Congratulations LMMasterMariner - your External Lathe Gearbox is the Homemade Tool of the Week!
Multiple very nice tools this week, but this impressive build was a rarity on this forum: a clear winner.
Screwhead Chuck by Christophe Mineau
QCTP Rocker Tool Posts by jjr2001
Simplified Bore Measurement Method by mklotz
Digital Air Pressure Controller by chy_farm
Double Disc Sander by Bellevue Woodshop
Rivet Snap Tool by thehomeengineer
Surface Gauge by CookieCrunch
Cable Anchor Belt Clip by rgsparber
Compound Slide Auto Feed by Christophe Mineau
Scribe, Finger Plate, and Tap Follower by CookieCrunch
Chuck Depth Stop by Christophe Mineau
Braii Starter by garage nut
Tiny Boring Bar by Christophe Mineau
Rear Tool Post Spacer by jjr2001
Rocker and Post Construction Method by Toolmaker51
SDS Drill Adaptor by Rorschach
Cherry Picker Modification by Viny
Boring Bar Tool Post by jjr2001
Extended Drill Bit by Christophe Mineau
LMMasterMariner - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
More importantly, this is your 5th Homemade Tool of the Week win! I've just added the silver wrench-on-pedestal graphic to the awards showcase in your postbit, visible underneath your avatar.
:rocker: :clapping: :thumbsup: :bow:https://www.homemadetools.net/forum/...OfTheWeek2.png:bow: :thumbsup: :clapping: :rocker:
Great job, and you're in excellent company joining these other 5-time winners: rossbotics, Christophe Mineau, Brendon, mklotz, Vyacheslav.Nevolya, brianhw, Tuomas, olderdan, tonyfoale.
Here are all of your wins. Congrats again :thumbsup:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/captains-lathe-reverse-tumbler-57855#post86377"> <img src="/uploads/169157/homemade-lathe-reverse-tumbler.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/captains-lathe-reverse-tumbler-57855#post86377">Lathe Reverse Tumbler</a> <span> by <a href="https://www.homemadetools.net/builder/LMMasterMariner">LMMasterMariner</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='https://www.homemadetools.net/tag/modification'>modification</a>, <a href='https://www.homemadetools.net/tag/gears'>gears</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/lathe-chuck-brake-61437#post93779"> <img src="/uploads/170021/homemade-lathe-chuck-brake.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/lathe-chuck-brake-61437#post93779">Lathe Chuck Brake</a> <span> by <a href="https://www.homemadetools.net/builder/LMMasterMariner">LMMasterMariner</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/brake'>brake</a>, <a href='https://www.homemadetools.net/tag/chuck'>chuck</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/ev-anvil-exhaust-valve-61824#post94834"> <img src="/uploads/201001/homemade-anvil-40.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/ev-anvil-exhaust-valve-61824#post94834">Anvil</a> <span> by <a href="https://www.homemadetools.net/builder/LMMasterMariner">LMMasterMariner</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/anvil'>anvil</a>, <a href='https://www.homemadetools.net/tag/exhaust'>exhaust</a>, <a href='https://www.homemadetools.net/tag/valve'>valve</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/keyway-cutter-66833#post108623"> <img src="/uploads/211579/homemade-keyway-cutter-8.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/keyway-cutter-66833#post108623">Keyway Cutter</a> <span> by <a href="https://www.homemadetools.net/builder/LMMasterMariner">LMMasterMariner</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/keyway'>keyway</a>, <a href='https://www.homemadetools.net/tag/cutter'>cutter</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/homemade-lathe-headstock-external-gearbox-67608#post110997"> <img src="/uploads/213419/homemade-external-lathe-gearbox.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/homemade-lathe-headstock-external-gearbox-67608#post110997">External Lathe Gearbox</a> <span> by <a href="https://www.homemadetools.net/builder/LMMasterMariner">LMMasterMariner</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='https://www.homemadetools.net/tag/gears'>gears</a> </div> </div> </div> </div>
And most deserving of the award
Well deserved, congratulations
Doug
