Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 31
Thread: Simple homemade tools for repairing dents in stainless steel tubes for boat rails.
    Apr 2014
    Gadgeteer's Tools
    Godt gjort!
  2. #12
    California, central coast
    C-Bag's Tools
    Quote Originally Posted by stainless stål View Post
    Thank you for your nice comment, C-Bag
    I have not made the belt sander. It's just a regular pipe sander. I've just made an elevation on the sides of the wheels to keep the belt better in place when I work fast sideways on tubes like in the video.
    Regards
    Olav
    Olav I don't mean to derail your post or take anything away from your DIY tools, but I've never seen a pipe sander before. Most of my life I've done metal work, but not much having to do with stainless. I had to do some refitting of some stainless fruit guides on a fruit sizer and it of course messed up the brushed finish. I found out they had a special horizontal abrasive drum on a variable speed angle grinder that could repair the finish. And without that our regular flap disc's had no way to make that style of finish. And just like with the fruit guide, trying to do the repair like you did would not look just like new without that particular sander.
    So when I did a search for a hand held belt sander I only came up with ones I was familiar with. Not until I went back and reread your reply did I notice "pipe sander". That brought up a whole slew of machines like yours. And the prices are staggering, the cheapest was almost $200 and going up to around $1500! So in my mind a DIY version of this type of sander as a bolt on attachment to my Makita 4 1/2" grinder is a worthy future project. If I was doing this kind of work all the time I could see buying one, but it's not something I do a lot of. But thank you for bringing it to my attention.
  3. The Following User Says Thank You to C-Bag For This Useful Post:
    Paul Jones (Jun 25, 2017)
  4. #13
    Supporting Member Kwick Aronson's Avatar
    Sep 2015
    Amazon has the sander with forty belts in four different grits for $188 Amazon Prime. Mine will be here Tuesday.
  5. #14
    Jun 2017
    Laborious but practical and beautiful result ! Olav, you are the best !
  6. #15
    Dec 2016
    Ralphxyz's Tools
    Wow, great video showing the repair process and results.
    Got to remember Pipe Sander.
    Seems like one could make one with a angle grinder ...
    Ralph
  7. #16
    Supporting Member stainless stål's Avatar
    Jun 2017
    Norway
    stainless stål's Tools
    First, I would like to thank you all for your kind comments
    Then:
    Ralph
    I have actually made such a sander for angle grinder a while ago. The speed of an angle grinder is too high so it must be regulated down, as I have done with gears, as you can see in the picture. It works fine so I'll make some safety covers around the gears.
    Simple homemade tools for repairing dents in stainless steel tubes for boat rails.-img_0362.jpg
    Regards
    Olav
  8. The Following 6 Users Say Thank You to stainless stål For This Useful Post:
    DIYer (Jun 27, 2017), LMMasterMariner (Jun 26, 2017), Paul Jones (Jun 25, 2017), rlm98253 (Jun 26, 2017), Seedtick (Jun 26, 2017), Toolmaker51 (Jun 26, 2017)
  9. #17
    Sep 2015
    Then:
    Regards
    Olav
    Holy-Moley BatMan!! Pretty darn trick!!
  10. #18
    In lieu of using a small right angle grinder to make one of these pipe sanders a rt angle polisher could be used many come with variable speed and their max RPM is only around 3000 RPM or less
  11. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    rlm98253 (Jun 26, 2017), stainless stål (Jun 26, 2017)
  12. #19
    May 2017
    Then:
    Regards
    Olav
    You can use one of those Router Speed Controllers from Harbor Freight (or elsewhere) to regulate the speed of the angle grinder. Those router controllers will turn single speed universal brush motors into variable speed tools. You can even use one on a shop vacuum to decrease suction.
  13. The Following User Says Thank You to Evergreen For This Useful Post:
  14. #20
    Related:
    Dremel belt sander attachment by Tuomas: Small beltsander/lathe attachment for rotary tool.
    Dremel pipe grinder by barberorp: homemade pipe grinding tool
  15. The Following User Says Thank You to Jon For This Useful Post:
