Thread: A 12V Battery Monitor for an Electric Car
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I own a Chevy Bolt EV. The designers did a masterful job monitoring the 400-volt traction battery, but ignored the 12-volt battery, which powers the car's computers.
    When my 12-volt AGM battery recently became weak, I saw random failures in the computers. A load test of this battery showed it was bad What I needed was an early warning that the battery was about to upset the computers.
    I have built a computer-based voltage monitor that continuously measures the 12-volt battery at its terminals. When it detects a voltage below 12.00 volts, it takes five more readings and then votes. If the voltage dip persists, it locks into an alarm state. An LED flashes and a beeper sounds. The alarm tells me to run a load test.
    Before you get excited about using a computer for such a simple task, understand that my computer is an ATTiny 85, which costs $3.33. The total cost of all parts is around $10.
    If you are interested, see https://github.com/rgsparber/Chevy-B...attery-Monitor (my website is temporarily down).
    My website is back up so you can get the document here.
    Rick
    Last edited by rgsparber; Mar 24, 2026 at 02:05 PM. Reason: change in document location
    Rick
  2. The Following 5 Users Say Thank You to rgsparber For This Useful Post:
    DIYer (Mar 24, 2026), ductape (Mar 23, 2026), emu roo (Mar 24, 2026), Jon (Apr 1, 2026), rlm98253 (Apr 22, 2026)
