Results 1 to 10 of 322
Thread: 1974 XS/TX650 rebuild
    Oct 2015
    th62's Tools
    This afternoon I taught myself to mig aluminium. The key was finding the right volts, wire feed, stick out, speed and watching the heat build up, that had me stumped for a bit, wondered why each successive run was worse than the last - heat build up!. Oh, a steady hand also helps, but that's beyond this old codger now, hence the wobbly runs. Excellent penetration too, after welding an external edge joint, I ground it down flat then belted the hell out of it trying to separate the joint. Not too bad for an hour or so practice. A whole new world of aluminium fabricating has opened up now, should have taught myself to weld aluminium year's ago. Talk about messy though, splatter everywhere. And I burnt the crap out of my arm from flash, the flash is 10 times brighter than when welding steel.
ID:	37916   Click image for larger version.
ID:	37917   Click image for larger version.
  2. The Following User Says Thank You to th62 For This Useful Post:
    olderdan (Jan 17, 2021)
There are currently 5 users browsing this thread. (0 members and 5 guests)
