Here's how they were made. i started with two strips of 3mm ally, 50mm x 230mm. worked out PI for 34mm fork legs and did two 90 degree bends Pi apart. I used a bit of angle iron with the edge radiused for the bends as this aluminium fractures if bent to acutely. I then bent the ally around a 34mm dolly, bringing the 90 degree bends together with a 3mm gap between when clamped tight. Of course I had to stuff it all up when I shaped it, didn't I, made two right handers instead of a right and a left. The joys of getting old. Oh well, soon as I make a lefty I'll shape, drill and polish Some polishing was done beforehand for the areas I won't be able to get to after bending.. I'll post pics of the completed brackets when finished. . i started with two strips of 3mm ally, 50mm x 230mm. worked out PI for 34mm fork legs and did two 90 degree bends Pi apart. I used a bit of angle iron with the edge radiused for the bends as this aluminium fractures if bent to acutely. I then bent the ally around a 34mm dolly, bringing the 90 degree bends together with a 3mm gap between when clamped tight. Of course I had to stuff it all up when I shaped it, didn't I, made two right handers instead of a right and a left. The joys of getting old. Oh well, soon as I make a lefty I'll shape, drill and polish Some polishing was done beforehand for the areas I won't be able to get to after bending.. I'll post pics of the completed brackets when finished.
