Results 1 to 10 of 10
Thread: 5 inch steady rest for Leblond 19 lathe
    When you buy older or used machines more often than not not much of the tooling comes with them.
    I needed a small steady rest for an up coming project I am wanting to build so the first step was to make one.
    I started out with a couple of 8" dia. 3/16" thick disc that were picked up at the local scrap metal yard. then bought 3 3/4" coupling nuts and a piece of all thread. All thread is not ideal for making the adjustable guides but suitable for a light duty rest.
    After welding the coupling nuts and discs together I bored out the center
    next I welded a 1/8" thick strap around the perimeter
ID:	9288 Click image for larger version.
    not wanting to try and make a hodge podge set up to mill a "V" grove in the base I elected to simply saw off the end of the sub base with my band saw
ID:	9290 Click image for larger version.
    Next I chucked the rest in the lathe and tacked the base and stand to it
    After welding I did a trial fit of the guides
ID:	9293 Click image for larger version.
    Then I machined one end of the guides and drilled a hole deep enough to accommodate a 10 mm bearing ball
    then I slightly struck the guides in 4 places around the ball to secure it in place, the ball still rolls freely in its socket.
ID:	9296 Click image for larger version.
    Next I cut the rest in two once the blade had cut nearly all the way through the first side the saw cut closed up binding the blade to free it I simply used a long piece of all thread and a piece of tubing to spread the rest open enough to free the blade
ID:	9298 Click image for larger version.
    After separating the 2 parts and trimming one for the hinge I tacked the hinge in place then welded it and the hold down lock tabs to the opposite side
ID:	9300 Click image for larger version.
    ready to use as soon as I drill 1 hole and clamp it down to the lathe
    Some day when I have the time I may paint it
  2. The Following 11 Users Say Thank You to Frank S For This Useful Post:
    baja (Jan 8, 2020), bobs409 (Jan 23, 2017), Carnel (Jan 8, 2020), hemmjo (Feb 25, 2026), Hopefuldave (May 27, 2019), kbalch (Mar 20, 2016), lavern s (Apr 23, 2018), mr mikey (Oct 14, 2023), mwmkravchenko (Apr 22, 2018), Paul Jones (Mar 20, 2016), Scotty12 (Jan 7, 2020)
