Yes it takes surprisingly little adjustment to change from a 1.5" OD roller to a 4" OD roller. TO make mine easy to change only the nut had to be removed from the idler roller slip 1 off slip the other on. At the motor end the motor was mounted on a 2 rail slide just like the movable vice jaw there was a compression spring on the screw a few turns to loosen or tighten the belt a few more to facilitate a roller diameter change.
The single round ball gear shift looking thing moved the vice in and out and from side to side allowing for even belt wear
and adjustable plate under the belt allowed for flat plane sanding or a fence could be added for sanding things perpendicular to the belt or at angles.
As much as I dislike having to built something twice since my tools never made it back from over there this is 1 that I will be making again.
