Results 1 to 6 of 6
Thread: 70 Amp MOT Stick Welder
    Supporting Member scorch's Avatar
    Apr 2015
    Oakdale, MN
    scorch's Tools
    Home made Microwave Oven Transformer (MOT) stick welder. I based my design on the welder by Randy Gross (Homemade 70-Amp Arc Welder). It looks like Randy's web site is gone now but my welder lives on. This welder is made from two transformers from old microwave ovens. The transformer secondary coils were rewound, to achieve welding voltage, with 10 AWG solid copper wire. I included a fan from one of the microwaves for cooling.
    (EDIT: here is a link to an archive of the original AAA Welder web page that I used as a guide to construct this welder.
    https://web.archive.org/web/20100411...com/70amp.html )
    Input: 120V, 20 Amp
    Open circuit voltage: 40 Volts
    Welding current: 73 Amps
    Rewound transformer secondary coils with 10 AWG solid copper wire.
    Welds best with 5/64 welding rod
  2. The Following 9 Users Say Thank You to scorch For This Useful Post:
    12L14 (Jul 31, 2019), Altair (May 24, 2015), Christophe Mineau (May 21, 2015), emu roo (Nov 29, 2025), EnginePaul (Aug 5, 2021), Jon (May 21, 2015), kbalch (May 21, 2015), ranald (Jun 27, 2019), Terer (Sep 12, 2017)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks scorch! I've added your Stick Welder to our Electrical category, as well as to your builder page: scorch's Homemade Tools. Your receipt:
  4. The Following User Says Thank You to kbalch For This Useful Post:
    Cool build! Thanks for the share.
    Nice work scorch. Looks like I'll be scouring for old microwaves now.
    Al
  8. The Following User Says Thank You to Altair For This Useful Post:
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    This thread has been moved to the Must Read subforum. Congrats (and thanks) to scorch for making such a valuable contribution!
  10. The Following User Says Thank You to kbalch For This Useful Post:
  11. #6
    Apr 2019
    I also made a DIY welder some years ago.
    The transformer that I found was easy to disassemble and the primary had 88 turns so I guessed that about 50 or so would do for the welding side.
    I used 1/4 " copper tubing to wind my secondary 'welding side' .
    I then poured varathane varnish to isolate the secondary.
    Surprise! It worked just great.
    From the rods that I used I determined that I was developing as much as the 5/16 rods demanded.
    Made many DIY projects with that rig. (and nothing ever failed)
    That ugly DIY welder was housed in a plywood box.
    OK, today I use a nice Hobart 200 amp 'real' welder but the skills learned with my DIY still pay off.
  12. The Following User Says Thank You to piloon For This Useful Post:
