Results 1 to 5 of 5
Thread: Band Saw Blade Soldering Jig
    Doc
    Doc is offline
    Supporting Member Doc's Avatar
    May 2013
    Doc's Tools
    Lightbulb Band Saw Blade Soldering Jig
    Hi all, firstly, no laughing.
    I'm a woodworker not a metalworker (although I'm trying)
    Secondly, this is my first attempt to post a mini tutorial on this forum, so bear with me.
    Here is a band saw blade holder for when I used to have a small band saw and break blades frequently.
    These are your basic ingredients:
    Basically a piece of square tubing with a slot cut out in it and some flat metal, both about the same length.
    Drill some holes to match whatever size bolt you wish to use and use a tap to make a thread in the tubing only.
    Place in a vice to hold the jig steady.
    You then simply break a blade or two (I was getting quite proficient at that!) then file/sand/grind the two ends to form a scarf joint.
    Solder away until your heart's content or you finish the solder joint
    As you can see from my soldering, I am a woodworker
    Judicious use of a grinder will smooth the blade after soldering and make you look like a better metalworker, but don't be fooled.
    Hopefully this post works. Feel free to ask questions - somebody more skilled than me will be able to answer
    By the way, this was from many years ago - I now have a much bigger industrial band saw and have never broken a blade. Just as well, since I can't find the jig anywhere.
    Regards
    Doc
    Attached Thumbnails Attached Thumbnails Band Saw Blade Soldering Jig-img_5107custom.jpg
  2. The Following 2 Users Say Thank You to Doc For This Useful Post:
    kbalch (Jan 2, 2015), Paul Jones (Jan 1, 2015)
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Yes, that's very good, I think I will modify mine to have the same system for clamping as yours.
    I like the fact that the two blade parts are aligned by the shaft of the screw, that's a great idea. You need to take care when drilling the four holes so that they are well aligned.
    Thanks for the trick !
    christophe
    Cheers !
    Christophe
    Facebook : La Belle Note
  4. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    Doc (Jan 2, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Doc! I've added your Bandsaw Blade Soldering Jig to our Bandsaws and Soldering categories, as well as to your builder page: Doc's Homemade Tools. Your receipt:
  6. The Following User Says Thank You to kbalch For This Useful Post:
    Doc (Jan 2, 2015)
    Doc
    Doc is offline
    May 2013
    Doc's Tools
    Thanks Christophe.
    If I remember correctly (always a gamble) but I reckon that I clamped the flat to the square tube to drill the holes 'accurately'.
    It was a long time ago now, but being as lazy as I am, that was probably how I did it
    Regards
    Doc
    Great contribution, Doc. Thanks!
  9. The Following 2 Users Say Thank You to DIYer For This Useful Post:
    Captainleeward (Jan 12, 2015), Doc (Jan 2, 2015)
