1) Arm seems to be swinging square to the table. I will replace the blade with a piece of wire to take out the effect of the set of the teeth.
2) Not sure how tight the blade should be. For now it is fairly tight. How do you measure?
3) No additional weight on the blade, just the weight of the arm assembly. I have turner the spring tensioner right down.
4) I do not have any other blades apart from the one I got with the machine.
5) I took the blade guides apart and cleaned everything before re-assembling as per a YouTube suggestion.
6) Will take photo of the vice tonight.
Thanks so long![]()
