Thread: Belt sander with a table grinder
    Supporting Member Made in Garage's Avatar
    Apr 2019
    Made in Garage's Tools
    I warmly welcome.
    He has been involved in the production of fishing baits for some time. Production may be too big a word because I make it only for my own use but the time needed to perform it discouraged me.
    And here came the idea to make a small belt grinder that I could move from the garage to the basement to grind wobbler bodies on winter evenings.
    For this purpose I used an old table grinder that does not sin with power but for processing small wooden elements it will be just right.
    I made the roller from several plywood wheels which I cut with a hole saw.
    The whole body was made of a flat bar 8mm thick.
    The steering roller and tensioning belt is a piece of tube with two bearings.
    The tension is a spring of unknown origin.
    You can see the entire production stage in the video below.
    The whole grinder was made of what I had at home. I await your opinions.
  2. The Following 7 Users Say Thank You to Made in Garage For This Useful Post:
    Andyt (Dec 25, 2019), IAMSatisfied (Dec 29, 2019), Jon (Dec 27, 2019), matt_albitz (Dec 24, 2019), rdarrylb (Dec 25, 2019), rlm98253 (Dec 24, 2019), Tule (Dec 26, 2019)
    Thanks Made in Garage! We've added your Belt Grinder to our Grinding category,
    as well as to your builder page: Made in Garage's Homemade Tools. Your receipt:
    ZulaZabor (Jan 27, 2020)
