Results 1 to 5 of 5
Thread: Bump straight knurling tool
    Supporting Member Cascao's Avatar
    Brasil
    Cascao's Tools
    Thumbs up Bump straight knurling tool
    After making a scissor knurling tool, I become intersted in making a straight knurling tool since it:
    > is greath when you need transmit torque between a steel shaft and a plastic wheel.;
    > it can bring me more choices when making stuff;
    > I can "save" a interference mount part infortunatelly made too loose.
    I took a 1/2" square and milled the wheel slot
    Turned the 1/4" pin from a 1045 bar. Here you can see there a section slighty bigger for interference fit
    Pin was heated red hot and quenched in water.
    After welding the side tab and cross drilling the 1/4" hole, I pressed the pin
    Test run. I've made a fine (0,8mm) and a coarse (1,25mm) wheel.
    My knurl set
    now waiting rain give a break for paint the tool...
    Last edited by Cascao; Jan 15, 2018 at 06:58 AM. Reason: fixing foregin language issues.
  2. The Following 10 Users Say Thank You to Cascao For This Useful Post:
    Andyt (Feb 27, 2020), blkadder (Jan 22, 2018), emu roo (Feb 26, 2026), Jon (Jan 15, 2018), mr95gst (Jan 16, 2018), olderdan (Jan 15, 2018), Paul Jones (Jan 15, 2018), PJs (Jan 16, 2018), rossbotics (Jan 19, 2018), Seedtick (Jan 15, 2018)
    olderdan's Tools
    Hi Cascao, nice work as usual,
    For what its worth I have found that straight knurl wheels will work just as well in your scissor tool.
    I have diamond knurls but prefer the straight ones and they have been mounted in my old scissor tool in the rear toolpost for years.
    I agree with your observations on their usfulness.
    Regards
    Olderdan
  4. The Following 3 Users Say Thank You to olderdan For This Useful Post:
    emu roo (Feb 26, 2026), Paul Jones (Jan 15, 2018), PJs (Jan 16, 2018)
    Brasil
    Cascao's Tools
    Olderan, didn't really know that straight knurl wheels can be used on scissor tools, nice to know. I belive (and hope) that since only one is needed, (the pressure on bearings is smaller) it is less harmfull to spindle bearings.
  6. The Following 4 Users Say Thank You to Cascao For This Useful Post:
    emu roo (Feb 26, 2026), olderdan (Jan 16, 2018), Paul Jones (Jan 15, 2018), PJs (Jan 16, 2018)
    Thanks Cascao! We've added your Knurling Tool to our Metalworking category,
    as well as to your builder page: Cascao's Homemade Tools. Your receipt:
    Brasil
    Cascao's Tools
    Ended making a QCTP 110 style knurling tool fix too.
  10. The Following User Says Thank You to Cascao For This Useful Post:
