Results 1 to 10 of 32
Thread: CNC Router
  1. #3
    Apr 2017
    UK
    editor@glue-it.com's Tools
    So, I've made T-nuts (a recurring theme here) for the Sain Smart Genmitsu 3018-Pro engraver/Router.
    Trouble was I didn't have the right size square bar...so I machined 3/4 inch diameter mild steel round bar into square:
    and eventually got to square
    and I ended up with six 14.4mm square nuts
    and they fit superb, will have to create a quick drawing for others to use
    The drawings might not happen, hence dimensions: The T-nuts are 14.4mm across, the square nut is 6mm high and has an 8mm diameter boss protruding 2mm from the top. The nut is threaded 6x1mm. They are threaded the whole way through the nut.
  2. The Following 8 Users Say Thank You to editor@glue-it.com For This Useful Post:
    Altair (Jul 29, 2020), Carnel (Jul 25, 2020), emu roo (Jul 18, 2025), Home-PC (Jul 25, 2020), Jon (Jul 24, 2020), old_toolmaker (Jul 25, 2020), Rocconet (Jul 25, 2020), Tonyg (Jul 25, 2020)
