Thread: Collet nut wrench
    Apr 2013
    Brisbane,Queensland, Australia.
    Ron B's Tools
    Collet nut wrench
    many years ago I was working as an engineer at saw mill where we had hundreds of bearings on tapered sleeves. The bearing race clearance was adjusted with a collet nut. Usually,the nuts were undone with a hammer and punch
    This meant we had piles of bashed up rings and these things are expensive. A proper wrench from the bearing manufacturer cost an arm and a leg so I made this.
    The hook is hinged to handle with a fork and blade arrangement . The hook goes into the slot on the nut and you pull or push on the handle to either do or undo it. It's made from a piece of truck spring leaf and lthough i've used it constantly for 35 years it;s still working well. i can even belt the end of the handle with a 2lb hammer to loosen really tight nuts.
    It comes in handy for the nuts on older mercedes rear axle bearings .Something i do for a bit of a living nowadays
    Attached Thumbnails Attached Thumbnails Collet nut wrench-jims-coupe-running-009.jpg   Collet nut wrench-jims-coupe-running-010.jpg
  2. The Following 2 Users Say Thank You to Ron B For This Useful Post:
    kbalch (Apr 25, 2013), Paul Jones (Feb 19, 2016)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Ron B! I've added your Collet Nut Wrench to our Metalworking category, as well as to your builder page: Ron B's Homemade Tools. Your receipt:
