couple of things spring to mind... #1 use a 125mm grinder (less to remove) or a 180mm if you can find one.
Using the 9", run the worn wheels against a brick, or old grindstone to bring them down
lastly (not nice) - use some bench shears to cut them down, then use the brick/stone trick to round them down under power.
