Results 1 to 4 of 4
Thread: cutting solid rivets to correct length to form button heads
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    I have quite a few solid rivets to shorten for dummy rivets on the horn plates of my 1" scale Minnie traction engine. So the criteria for the tool was to be able to cut several rivets at a time and maintain consistent length accuracy.
    Horn plate and rivet cutting tool.
    The tool is basically a guillotine that is loaded with rivets and the length is set by shims under the head of the rivet.
    Shims, 3 different thickness. I have access to a CNC mill and made the shims using this method.
Name:	chain drilling.jpg
ID:	33482 Click image for larger version.
Name:	clearing chain drilling.jpg
ID:	33483 Click image for larger version.
Name:	body roughed out.jpg
    Machining main body and sliding cutter
Name:	heat treated.jpg
    Heat treated sliding cutter
Name:	unassembled cutter.jpg
    Completed unassembled cutter.
Name:	additional cutters.jpg
ID:	33496 Click image for larger version.
Name:	width of cutters.jpg
    Additional cutters and the thickness of each
Name:	assembeled guillotine.jpg
ID:	33487 Click image for larger version.
Name:	spring return.jpg
    Assembled cutter and spring return in left photo
Name:	shim in place.jpg
    Shim in place
Name:	Arbour press.jpg
ID:	33490 Click image for larger version.
Name:	tool on press.jpg
    Arbour press used to apply pressure to cut
    Test cut
ID:	33493 Click image for larger version.
    Right rivet head the rivet was to long so the head didn't form correctly the left rivet was the trimmed rivet. The 2nd photo shows the preformed head side.
    Storage box for rivet tooling
    Arrand tools did make a rivet cutter but I couldn't find any information other than a friend has one and you can only cut one rivet at a time and washers need to be made to set length. If anyone has one I would be interested in seeing some photos of the design.
    Thank you for taking the time to view
    The Home Engineer
  2. The Following 12 Users Say Thank You to thehomeengineer For This Useful Post:
    baja (Feb 11, 2020), earl (Feb 10, 2020), emu roo (May 16, 2026), greyhoundollie (Feb 16, 2020), Jon (Feb 13, 2020), mr mikey (Jun 22, 2022), olderdan (Feb 9, 2020), Paul Jones (Feb 8, 2020), Sleykin (Jul 30, 2023), sossol (Jun 23, 2022), threesixesinarow (Feb 11, 2020), Toolmaker51 (Jun 22, 2022)
