Dead simple lathe tool height gauge
Like most neophyte machinists I soon realized that I needed a tool height gauge for setting the height of my lathe tools. My research uncovered a succession of what I can only describe as the most over-designed, complicated, hard-to-use devices I could imagine. As a devotee of the idea that simple is better I made a gauge that consists of nothing more than a block of steel relieved on the bottom...
so that it will sit flat and not rock when placed on a flat surface. The height of the block was carefully machined to match the height of the lathe spindle above the top of the compound. (Thankfully, my compound has a flat top; not all lathes do.)
Its use is simple. Push it up against the tool tip and slide your thumbnail back and forth between the gauge surface and the tool. Millions of years of evolution have made our fingers extremely sensitive; you'll be able to detect a few thousandths height difference and tell whether the tool is high or low as well.
Remarkably simple and beneficial!
Quote:
Originally Posted by
mklotz
Marv, you never cease to amaze me! I have my grandfather's 1946 Craftsman/Atlas 618 metal lathe Light duty with adjustable bronze bushings in the head stock) and I have been doing all sorts of research regarding best/easiest way to set my tool height. I could have saved my self a whole lot of headache by just asking you! This machined block will be made by chucking it up in my 4-jaw and facing a piece of square bar stock I have laying around. It will be a great project for a beginner like me. It will be my first time to do something like this. I usually work on round things. You are right when you say most of the other ones are over engineered (especially qif the need any sort of electrical parts). Have a great day and keep on inventing things!
