Steve,
Your searches turned up more than mine. This is all I found and is what I bought. I don't seem to very good at composing good search phrases.
Data Cable for Chinese Digital Calipers and Linear Scales Custom DRO Project NEW | eBay
However, I'd be wary of buying any of those others without more detail on which data formats they work with. I think that the igaging will only be compatible with igaging stuff. In addition since I got the cable I have found that not only does the data format vary from instrument to instrument but so does the socket detail. The cable I got had been moulded a tad too large so it needed a bit of shaving to fit the calipers and digital indicator with "supposedly" a matching socket, but it was too narrow for two other calipers that I tried it on. They have 4 contacts with the same spacing but without a touch of super-glue and tiny pieces of plastic you couldn't guarantee that the plug and socket contacts would stay aligned.
i have a couple of applications for which I need to get measurements into a PC which is what had prompted my interest in this. To be realistic I don't need to pass data from all my calipers etc. to a PC and now that I have a nice linear encoder the incentive to play around has largely evaporated. Getting the encoder data into my software is very easy
This afternoon I got my cam profile measuring thingy up and running with the new encoder and I couldn't be happier with how well it works. Generally measured cam data needs considerable filtering which loses real data not just noise. This need is driven because cam analysis needs getting the first 3 derivatives of the displacement and each differentiation step enhances the noise. With my new setup, the results only need 1/4 of the number of filtering passes that I had to do with manually derived data.
Anyway when I get a moment I'll make a proper post about the system.
I got lucky with the first search, as the eBay suggestions came up with the other examples.
I'm in 100% agreement with compatibility. It's too bad this is not a standard (like RS232), then you could trust an off the shelf data reader. And the iGaging gave me the exact same opinion, once I saw another add for the reader with the caliper.
