Thread: DIY Rivnut Tool
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    DIY Rivnut Tool
    Riveter for rivet nuts suitable for Num 3,4,5,6,8.
    Materials
    Flat bar 20x3mm
    Bolts/long nuts M12x1.75mm (If I remake it I will use M12x1.25mm)
    Small pieces of left over steel
ID:	39783 Click image for larger version.
ID:	39784 Click image for larger version.
    I haven’t a lathe so I made the needed fittings using the same way
    that I had made the threaded insert for my angle grinder.
    Place/secure a piece of steel 30x30mm at my drill press
    Make an M12x1.75 threat
    And using the threat makes the needed fittings.
  2. The Following 3 Users Say Thank You to kess For This Useful Post:
    Home-PC (Jun 11, 2021), Jon (Jun 10, 2021), that_other_guy (Jun 14, 2021)
