Results 1 to 5 of 5
Thread: DIY Welding Rod Holders - Rod Oven Alternative (4K)
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    Keep your welding rods dry. I don't have space for a rod oven, so I have to keep my rods dry from the start. I made these air tight holders and put rods in there straight from the package. Works pretty well; don't see any signs of water/rust on the rods after months of storage.
    Materials Used:
    - PVC pipe (diameter big enough to hold 1 pack rods. Length about 2 cms or 1" longer than rods, including end caps)
    - 1 Female end fitting
    - 1 Male cap for end fitting
    - 1 Pipe cap
    - Pipe glue
    - Bolt or other for grip
    - (optional) brass plug for flush hole
    - Teflon tape
    WARNING: The video depicts acts and work that, if done wrong or used improperly, can lead to injury or death. By watching this video, you agree the video's producer is not responsible for any such damage, injury or death. Always use proper safety procedures and safety equipment. If you don't know, learn first or don't do it.
  2. The Following 6 Users Say Thank You to tsbrownie For This Useful Post:
    Andyt (Mar 11, 2020), baja (Mar 16, 2020), clydeman (Mar 15, 2020), Jon (Mar 13, 2020), Quinton 357 (Mar 10, 2020), Tule (Mar 11, 2020)
    Thanks tsbrownie! We've added your Welding Rod Storage Canister to our Storage and Organization category,
    as well as to your builder page: tsbrownie's Homemade Tools. Your receipt:
    tsbrownie (Mar 9, 2020)
    Supporting Member basil3w's Avatar
    Mar 2012
    Flushing with inert dry gas is a great idea. What about making a removable screened area in the screw cap to hold some of those 'Do Not Eat' desiccant packs that we seem to get with most everything?
  6. The Following User Says Thank You to basil3w For This Useful Post:
    tsbrownie (Mar 11, 2020)
    Unkle Fuzzy's Avatar
    Near Monkeytown, USA
    I simpler method would be to install a check valve and vacuum pack the rods in storage.
    The same method would re-dry damp rods at room temperature overnight.
    Feb 2019
    tsbrownie's Tools
    Good idea. And with the steel bolt there you can use a strong magnet to hold it in place.
