Results 1 to 10 of 22
Thread: Filing Machine
    Dec 2013
    Florida
    rossbotics's Tools
    Filing Machine
    I built this filing machine for the sole purpose of being able to file 90 degrees from a flat surface and to maintain that squareness no matter what shape or geometry I'm filing, I have used filing machines in different shops years ago and loved them, I do a little gunsmithing from time to time and everyone knows how intricate these little parts can be, You can only do so much with a conventional Milling Machine, Unless you have a CNC Mill which I don't have !!! So this was my only alternative.
    It doesn't have an overhead support for the file because the thickest material I'll be filing will never exceed .250"
    I made a ball and socket to hold any shape file, the ball and socket also allows me to square the file with the table very accurately, the crankshaft has a 1.250" stroke,
    Below are some photos
    Thanks for looking and Happy Machining
    Doug
    Above shows all the machined and finished pieces before assembly
    Above shows the ball with a file in it, the socket is to the left of the file, the knurled nut is to the right of the file, all made from 4140 then heat treated and polished
    Above shows the file inserted into the ball and socket with a knurled retaining nut, the socket and nut both have the same radius machined into them as the ball
    Above shows the machine housing, fabricated from 1018 CRS, painted Rust-Oleum black hammered finish, the file assembly is just sitting on top
    Above shows the crankshaft installed into the housing, the crank is supported by two R10 sealed ball bearings
    Above shows the housing with the crankshaft and bronze linear bearing fitted over the crank pin, the crankshaft was made from 2" round pre-heat treated 4140, the crank pin is a hardened 3/8" dowel
    Above shows the linear bearing housing which is 4140 heat treated steel, slipped over the bronze bearing with the vertical shaft locked into the bearing housing by two 5/16" set screws
    Above shows the housing with the file holder installed on the vertical shaft, the precision ground table is ready for installation, the table was made from .500" X 6" X 10" 1018 CRS
    Above shows the machine completely assembled with it's motor and switch sitting on a cherry wood base
    Above shows another view of completed machine
    Here is a link to the you tube video of the machine
  2. The Following 31 Users Say Thank You to rossbotics For This Useful Post:
    12L14 (Jul 31, 2019), Andyt (Nov 26, 2018), baja (Jul 23, 2021), byates (Apr 10, 2023), Canyonman44 (Jul 22, 2021), Charron63 (Nov 29, 2017), cogentia (Jul 22, 2021), Corm (Nov 24, 2018), emu roo (Nov 13, 2023), greyhoundollie (Nov 24, 2018), high-side (Aug 6, 2018), Home-PC (Feb 22, 2023), j.bickley (Nov 14, 2017), JRock (Apr 15, 2018), jrouche (Nov 15, 2017), kbalch (Oct 27, 2014), KustomsbyKent (Nov 25, 2018), Metallurg33 (Apr 14, 2018), mr mikey (Apr 22, 2024), mwmkravchenko (Jul 23, 2021), myavid76 (Aug 6, 2018), oldcaptainrusty (Nov 15, 2017), old_toolmaker (Jul 23, 2021), Paul Jones (Oct 29, 2014), PJs (Jun 16, 2015), rlm98253 (Nov 14, 2017), savageseas (Nov 16, 2017), Toolmaker51 (Nov 16, 2017), Tuomas (Nov 16, 2017), Ukenick (Jun 7, 2019), Workshopshed (Oct 29, 2014)
