Results 1 to 10 of 21
Thread: grove cutting tool
Hybrid View
    Oct 2017
    if cutting grooves in precison machined mating surface is not your thing ,, Its not mine.. just use permatex aviation form a gasket ,gasket sealer , or what ever its called these days, the dark brown black thick gooey stuff.to both sides of your gasket, nothing i have leaks oil !!!!!! and no i am NOT a fan of silicon sealer for engines and such , its made for weather stripping, and caulking use..
  2. The Following User Says Thank You to madokie For This Useful Post:
    NortonDommi (Jun 24, 2018)
    Apr 2018
    Hylomar sealant
    Quote Originally Posted by madokie View Post
    Hi
    The Aviation sealer works but it is a PITA to take the unit apart afterwards and to clean before assembly. Try using Permatex Hylomar it seals just as well but is easy to disassemble and clean up for reassembly. Originally made by Rolls Royce to seal their engines. Use it on all my motors and no oil leak issues to deal with.
  4. The Following 2 Users Say Thank You to 11thhourfabrication For This Useful Post:
    NortonDommi (Jun 24, 2018), olderdan (Jun 24, 2018)
    Jul 2018
    Flora, MS
    Floradawg's Tools
    I used Permatex on the VW engine I rebuilt. That was the way it was usually done. Kind of gluing the crankcase halves together.
