Thank you PJs!
I'm a bit undecided at the time, I have to install this set on a Lm3886 amp, not so much current used to the output. I'm building a compact frame, since the old one I built 15 years ago has some trouble, my skills and equipment were very limited and I made bad decision above all on anchoring system.
The new frame is my usual steel frame welded, with aluminum panels, I will use Iroko wood for sides, I'm thinking about using this good wood even as insulator, do you think it could be a right choice? I have this wood in safe place, inside house for at least 25 years
