Quote Originally Posted by rendoman View Post
Thank you PJs!
I'm a bit undecided at the time, I have to install this set on a Lm3886 amp, not so much current used to the output. I'm building a compact frame, since the old one I built 15 years ago has some trouble, my skills and equipment were very limited and I made bad decision above all on anchoring system.
The new frame is my usual steel frame welded, with aluminum panels, I will use Iroko wood for sides, I'm thinking about using this good wood even as insulator, do you think it could be a right choice? I have this wood in safe place, inside house for at least 25 years
Beautiful wood. My Djembe from Burkina Faso is made from it I believe, for its resonant properties. Personally I would put some kind of insulator on it with thin walls and for sake of ease, use white/black Delrin (Acetyl). Perhaps 2 top hat types per, inside and out...easy enough to make. Since you are likely only pushing <100W it would probably be fine through the wood. It's old enough and dry enough I would think after 25yrs of acclimatizing, but there may be a certain resistance across it, which you could measure with an Ohm Meter. Safer than sorry is my motto.
~PJ
